It is currently Sat Aug 16, 2025 9:09 pm
PostPosted: Fri Aug 29, 2014 3:04 pm
First name: Stuart
Last Name: Gort
This edge gluing tool works particularly well at applying side pressure and holding down the stock to a flat surface while it's being glued. I built some versatility into it to deal with a range of heights and widths.
Thought I'd show it off...and yes....it's metal...but perhaps aspects of it could be useful to others. It could be replicated in wood and work very well.
StuMusic
PostPosted: Fri Aug 29, 2014 3:30 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Stuart,
Great looking fixture ..... but it looks extremely slow to use......
Check this fixture out.... http://www.advmachinery.com/p-24-plano- ... press.aspx
Maybe you can adapt some ideas that would make it faster..
Blessings,
Kevin
PostPosted: Fri Aug 29, 2014 3:53 pm
I think aluminum bar clamps might be more practical and faster -- your device looks very nice though.
PostPosted: Fri Aug 29, 2014 4:07 pm
First name: Stuart
Last Name: Gort
Kevin Waldron wrote:
Stuart,
Blessings,
Kevin
Haha...there's nothing slow about using it except waiting for the epoxy to cure. The day THAT'S a problem is the day I heat the bottom platen to accelerate the cure.
Once the glue is applied it takes about five minutes to jig it up in this fixture.
StuMusic
PostPosted: Fri Aug 29, 2014 4:10 pm
First name: Stuart
Last Name: Gort
Those top clamps only apply a small amount of pressure. The only purpose is to keep the stock from buckling in the joint area. The stock can actually move sideways a little. These just hold it flat down to the plate.
StuMusic
PostPosted: Fri Aug 29, 2014 5:28 pm
First name: D
Last Name: S
That's dandy, Stuart!
Can't wait to see what the Zebra wood transforms into.
Dan
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Stuart Gort (Sat Aug 30, 2014 9:30 pm)
PostPosted: Sat Aug 30, 2014 9:17 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Stuart, I'm impressed! I should probably put more time in my jigs, and save some time in the long run.
These users thanked the author mkellyvrod for the post: Stuart Gort (Sat Aug 30, 2014 9:30 pm)
Users browsing this forum: pkdz and 10 guests
